Giriş
Replacing the speaker requires soldering and extensive disassembly. Refer to iFixit's soldering guide if you have never used a soldering iron or if you need a refresher.
Neye ihtiyacın var
On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
Bu adımda kullanılan alet:Tweezers$4.99
Remove the two screw covers at the top of phone with tweezers.
Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
Gently pry the LCD ribbon from the left side of the front cover using the plastic opening tool.
Use a soldering iron to desolder the lead junctions. If you have never used a soldering iron or you need a refresher, check out iFixit's soldering guide.
Separate the speaker from the LCD screen.
2 farklı kişi bu kılavuzu tamamladı.
