Ana içeriğe geç
LG CF360 LCD Screen Replacement
Neye ihtiyacın var
    1. LG CF360 LCD Screen Replacement, Battery: adım 1, 2 resimden 1. LG CF360 LCD Screen Replacement, Battery: adım 1, 2 resimden 2.
      • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
      FixBot'a Sor
      Yorum Ekle
    2. LG CF360 LCD Screen Replacement: adım 2, 1 resimden 1.
      • Lift and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG CF360 LCD Screen Replacement, Back Cover: adım 3, 2 resimden 1. LG CF360 LCD Screen Replacement, Back Cover: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the two screw covers at the top of phone with tweezers.
      FixBot'a Sor
      Yorum Ekle
    2. LG CF360 LCD Screen Replacement: adım 4, 1 resimden 1.
      • Remove the six Phillips #000 (3mm) screws.
      FixBot'a Sor
      Yorum Ekle
    3. LG CF360 LCD Screen Replacement: adım 5, 3 resimden 1. LG CF360 LCD Screen Replacement: adım 5, 3 resimden 2. LG CF360 LCD Screen Replacement: adım 5, 3 resimden 3.
      • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
      • The plastic side buttons fall out when you take the back cover off.
      • The back cover is connected to the speaker by red and black wires.
      FixBot'a Sor
      Yorum Ekle
    4. LG CF360 LCD Screen Replacement: adım 6, 1 resimden 1.
      • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
      • Set the back cover with the speaker aside.
      FixBot'a Sor
      Yorum Ekle
    1. LG CF360 LCD Screen Replacement, Motherboard: adım 7, 2 resimden 1. LG CF360 LCD Screen Replacement, Motherboard: adım 7, 2 resimden 2.
      • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
      • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
      FixBot'a Sor
      Yorum Ekle
    2. LG CF360 LCD Screen Replacement: adım 8, 1 resimden 1.
      • Gently remove the blue transparent tape from the connector.
      FixBot'a Sor
      Yorum Ekle
    3. LG CF360 LCD Screen Replacement: adım 9, 1 resimden 1.
      • With the plastic opening tool, gently pry the LCD connector from the motherboard.
      • Set the motherboard aside.
      FixBot'a Sor
      Yorum Ekle
    1. LG CF360 LCD Screen Replacement, Front Case: adım 10, 1 resimden 1.
      • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
      FixBot'a Sor
      Yorum Ekle
    2. LG CF360 LCD Screen Replacement: adım 11, 1 resimden 1.
      • Gently pull the orange ribbon from the number pad casing.
      • Set the number pad case to the side once it is detached from the ribbon.
      FixBot'a Sor
      Yorum Ekle
    3. LG CF360 LCD Screen Replacement: adım 12, 1 resimden 1.
      • Remove the two red sticker screw coverings at the top corners with tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. LG CF360 LCD Screen Replacement: adım 13, 1 resimden 1.
      • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. LG CF360 LCD Screen Replacement: adım 14, 2 resimden 1. LG CF360 LCD Screen Replacement: adım 14, 2 resimden 2.
      • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
      • Set the red sliding backing and front cover to the side.
      FixBot'a Sor
      Yorum Ekle
    1. LG CF360 LCD Screen Replacement, LCD Screen: adım 15, 1 resimden 1.
      • Be very careful to not damage the green keypad board when using the plastic opening tool.
      • Use a plastic opening tool to carefully disconnect the silver L-shaped LCD screen ribbon.
      FixBot'a Sor
      Yorum Ekle
    2. LG CF360 LCD Screen Replacement: adım 16, 2 resimden 1. LG CF360 LCD Screen Replacement: adım 16, 2 resimden 2.
      • At this point, an orange ribbon is still connected to the white and black Zero Insertion Force (ZIF) connector on the keypad board. Be careful to not damage the ribbon.
      • Use tweezers to carefully pry up the black retainer on the connector.
      FixBot'a Sor
      Yorum Ekle
    3. LG CF360 LCD Screen Replacement: adım 17, 2 resimden 1. LG CF360 LCD Screen Replacement: adım 17, 2 resimden 2.
      • Lift the keypad board away from the phone casing using a plastic opening tool.
      • Slowly rotate the keypad board towards you to disconnect the second orange LCD screen ribbon and remove the board.
      FixBot'a Sor
      Yorum Ekle
    4. LG CF360 LCD Screen Replacement: adım 18, 1 resimden 1.
      • If you have never soldered before, or need a refresher, take a look at iFixit's soldering guide before starting this step.
      • Use a soldering iron and a solder wick to de-solder the 4 wires connected to the LCD screen.
      • The LCD screen can easily be removed at this point by lifting it from the phone casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ricky Wai
299 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-27, Amido Fall 2013 Cal Poly, Team 4-27, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G27
4 Üyeler
80 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,662
