Ana içeriğe geç
LG Front Load Washing Machine Air Dome Replacement
Neye ihtiyacın var
  1. LG Front Load Washing Machine Air Dome Replacement, Safety Precautions: adım 1, 2 resimden 1. LG Front Load Washing Machine Air Dome Replacement, Safety Precautions: adım 1, 2 resimden 2.
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    FixBot'a Sor
    Yorum Ekle
  2. LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
    • Remove the screw(s) securing the rear panel.
    FixBot'a Sor
    Yorum Ekle
  3. LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: adım 3, 3 resimden 1. LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: adım 3, 3 resimden 2. LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: adım 3, 3 resimden 3.
    • Unclip the rear panel from the chassis.
    FixBot'a Sor
    Yorum Ekle
  4. LG Front Load Washing Machine Air Dome Replacement: adım 4, 1 resimden 1.
    • Remove the rear panel.
    FixBot'a Sor
    Yorum Ekle
  5. LG Front Load Washing Machine Air Dome Replacement, Disconnect the air dome: adım 5, 2 resimden 1. LG Front Load Washing Machine Air Dome Replacement, Disconnect the air dome: adım 5, 2 resimden 2.
    • Pull the hose straight off the air dome hose to disconnect it.
    FixBot'a Sor
    Yorum Ekle
  6. LG Front Load Washing Machine Air Dome Replacement, Unfasten the air dome: adım 6, 1 resimden 1.
    • Remove the screw(s) securing the air dome.
    FixBot'a Sor
    Yorum Ekle
  7. LG Front Load Washing Machine Air Dome Replacement: adım 7, 3 resimden 1. LG Front Load Washing Machine Air Dome Replacement: adım 7, 3 resimden 2. LG Front Load Washing Machine Air Dome Replacement: adım 7, 3 resimden 3.
    • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
    FixBot'a Sor
    Yorum Ekle
  8. LG Front Load Washing Machine Air Dome Replacement, Remove the air dome: adım 8, 2 resimden 1. LG Front Load Washing Machine Air Dome Replacement, Remove the air dome: adım 8, 2 resimden 2.
    • Pull the air dome straight off its hose to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Bill Gilbert
40.143 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.531 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 23
Son 30 gün: 95
Her zaman: 2,214
