Ana içeriğe geç
LG Front Load Washing Machine Control Panel Replacement
Neye ihtiyacın var
  1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: adım 1, 2 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: adım 1, 2 resimden 2.
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    FixBot'a Sor
    Yorum Ekle
  2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: adım 2, 3 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: adım 2, 3 resimden 2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: adım 2, 3 resimden 3.
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    FixBot'a Sor
    Yorum Ekle
  3. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: adım 3, 2 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: adım 3, 2 resimden 2.
    • Slide the top panel towards the rear of the device to disconnect its clips.
    FixBot'a Sor
    Yorum Ekle
  4. LG Front Load Washing Machine Control Panel Replacement: adım 4, 2 resimden 1. LG Front Load Washing Machine Control Panel Replacement: adım 4, 2 resimden 2.
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    FixBot'a Sor
    Yorum Ekle
  5. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: adım 5, 2 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: adım 5, 2 resimden 2.
    • Pull the detergent drawer away from the chassis as far as it will go.
    FixBot'a Sor
    Yorum Ekle
  6. LG Front Load Washing Machine Control Panel Replacement: adım 6, 3 resimden 1. LG Front Load Washing Machine Control Panel Replacement: adım 6, 3 resimden 2. LG Front Load Washing Machine Control Panel Replacement: adım 6, 3 resimden 3.
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
    FixBot'a Sor
    Yorum Ekle
  7. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: adım 7, 3 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: adım 7, 3 resimden 2. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: adım 7, 3 resimden 3.
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
    FixBot'a Sor
    Yorum Ekle
  8. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: adım 8, 2 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: adım 8, 2 resimden 2.
    • Remove the screw(s) securing the control panel.
    FixBot'a Sor
    Yorum Ekle
  9. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: adım 9, 1 resimden 1.
    • Remove the screw(s) securing the detergent dispenser.
    FixBot'a Sor
    Yorum Ekle
  10. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: adım 10, 3 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: adım 10, 3 resimden 2. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: adım 10, 3 resimden 3.
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
    FixBot'a Sor
    Yorum Ekle
  11. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: adım 11, 3 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: adım 11, 3 resimden 2. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: adım 11, 3 resimden 3.
    • Remove the control panel, making sure to thread any cables through the chassis.
    FixBot'a Sor
    Yorum Ekle
  12. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: adım 12, 1 resimden 1.
    • Flip the control panel over.
    • Remove the screw(s) securing the control panel board.
    FixBot'a Sor
    Yorum Ekle
  13. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: adım 13, 3 resimden 1. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: adım 13, 3 resimden 2. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: adım 13, 3 resimden 3.
    • Pull the control panel board out of its slot and remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Bill Gilbert
39.917 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.572 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 65
Son 30 gün: 207
Her zaman: 5,317
