Ana içeriğe geç
LG Front Load Washing Machine Door Latch Replacement
Neye ihtiyacın var
    1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: adım 1, 2 resimden 1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: adım 1, 2 resimden 2.
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Door Latch Replacement, Open the door: adım 2, 2 resimden 1. LG Front Load Washing Machine Door Latch Replacement, Open the door: adım 2, 2 resimden 2.
      • Open the front door completely.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: adım 3, 3 resimden 1. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: adım 3, 3 resimden 2. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: adım 3, 3 resimden 3.
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      FixBot'a Sor
      Yorum Ekle
    3. LG Front Load Washing Machine Door Latch Replacement: adım 4, 3 resimden 1. LG Front Load Washing Machine Door Latch Replacement: adım 4, 3 resimden 2. LG Front Load Washing Machine Door Latch Replacement: adım 4, 3 resimden 3.
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      FixBot'a Sor
      Yorum Ekle
    4. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: adım 5, 3 resimden 1. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: adım 5, 3 resimden 2. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: adım 5, 3 resimden 3.
      • Use your fingers to pull the boot off its lip in the front panel.
      FixBot'a Sor
      Yorum Ekle
    5. LG Front Load Washing Machine Door Latch Replacement: adım 6, 3 resimden 1. LG Front Load Washing Machine Door Latch Replacement: adım 6, 3 resimden 2. LG Front Load Washing Machine Door Latch Replacement: adım 6, 3 resimden 3.
      • Work your fingers around the boot's perimeter until it's completely separated from the panel.
      FixBot'a Sor
      Yorum Ekle
    6. LG Front Load Washing Machine Door Latch Replacement: adım 7, 2 resimden 1. LG Front Load Washing Machine Door Latch Replacement: adım 7, 2 resimden 2.
      • Use your hands to fold the boot into the drum.
      FixBot'a Sor
      Yorum Ekle
    7. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: adım 8, 1 resimden 1.
      • Remove the screw(s) securing the door latch.
      FixBot'a Sor
      Yorum Ekle
    8. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: adım 9, 3 resimden 1. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: adım 9, 3 resimden 2. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: adım 9, 3 resimden 3.
      • Reach between the boot and the chassis to grip the door latch.
      • Pull the door latch out of its slot in the chassis to expose it.
      • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
      FixBot'a Sor
      Yorum Ekle
    9. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: adım 10, 2 resimden 1. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: adım 10, 2 resimden 2.
      • Disconnect the cable harness from the door latch.
      • Always grip cables by their connectors and not the wires themselves.
      • Remove the door latch.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Bill Gilbert
40.177 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
63.057 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 90
Son 30 gün: 378
Her zaman: 11,153
