Ana içeriğe geç
LG Front Load Washing Machine Pump Assembly Replacement
Neye ihtiyacın var
  1. LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: adım 1, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: adım 1, 2 resimden 2.
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    FixBot'a Sor
    Yorum Ekle
  2. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: adım 2, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: adım 2, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: adım 2, 3 resimden 3.
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    FixBot'a Sor
    Yorum Ekle
  3. LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: adım 3, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: adım 3, 2 resimden 2.
    • Slide the top panel towards the rear of the device to disconnect its clips.
    FixBot'a Sor
    Yorum Ekle
  4. LG Front Load Washing Machine Pump Assembly Replacement: adım 4, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement: adım 4, 2 resimden 2.
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    FixBot'a Sor
    Yorum Ekle
  5. LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: adım 5, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: adım 5, 2 resimden 2.
    • Pull the detergent drawer away from the chassis as far as it will go.
    FixBot'a Sor
    Yorum Ekle
  6. LG Front Load Washing Machine Pump Assembly Replacement: adım 6, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement: adım 6, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement: adım 6, 3 resimden 3.
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
    FixBot'a Sor
    Yorum Ekle
  7. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: adım 7, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: adım 7, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: adım 7, 3 resimden 3.
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
    FixBot'a Sor
    Yorum Ekle
  8. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: adım 8, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: adım 8, 2 resimden 2.
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
    FixBot'a Sor
    Yorum Ekle
  9. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the detergent dispenser: adım 9, 1 resimden 1.
    • Remove the screw(s) securing the detergent dispenser.
    FixBot'a Sor
    Yorum Ekle
  10. LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: adım 10, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: adım 10, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: adım 10, 3 resimden 3.
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
    FixBot'a Sor
    Yorum Ekle
  11. LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: adım 11, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: adım 11, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: adım 11, 3 resimden 3.
    • Remove the control panel, making sure to thread any cables through the chassis.
    FixBot'a Sor
    Yorum Ekle
  12. LG Front Load Washing Machine Pump Assembly Replacement, Open the door: adım 12, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Open the door: adım 12, 2 resimden 2.
    • Open the front door completely.
    FixBot'a Sor
    Yorum Ekle
  13. LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: adım 13, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: adım 13, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: adım 13, 3 resimden 3.
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
    FixBot'a Sor
    Yorum Ekle
  14. LG Front Load Washing Machine Pump Assembly Replacement: adım 14, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement: adım 14, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement: adım 14, 3 resimden 3.
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
    FixBot'a Sor
    Yorum Ekle
  15. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: adım 15, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: adım 15, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: adım 15, 3 resimden 3.
    • Use your fingers to pull the boot off its lip on the front panel.
    FixBot'a Sor
    Yorum Ekle
  16. LG Front Load Washing Machine Pump Assembly Replacement: adım 16, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement: adım 16, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement: adım 16, 3 resimden 3.
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
    FixBot'a Sor
    Yorum Ekle
  17. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: adım 17, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: adım 17, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: adım 17, 3 resimden 3.
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
    FixBot'a Sor
    Yorum Ekle
  18. LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: adım 18, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: adım 18, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: adım 18, 3 resimden 3.
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
    FixBot'a Sor
    Yorum Ekle
  19. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the filter trim: adım 19, 1 resimden 1.
    • Remove the screw(s) securing the filter trim.
    FixBot'a Sor
    Yorum Ekle
  20. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: adım 20, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: adım 20, 2 resimden 2.
    • Pull the filter trim straight off the front panel to remove it.
    FixBot'a Sor
    Yorum Ekle
  21. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the lower front panel: adım 21, 1 resimden 1.
    • Remove the screw(s) securing the lower front panel.
    FixBot'a Sor
    Yorum Ekle
  22. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the door latch: adım 22, 1 resimden 1.
    • Remove the screw(s) securing the door latch.
    FixBot'a Sor
    Yorum Ekle
  23. LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: adım 23, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: adım 23, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: adım 23, 3 resimden 3.
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
    FixBot'a Sor
    Yorum Ekle
  24. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: adım 24, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: adım 24, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: adım 24, 3 resimden 3.
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
    FixBot'a Sor
    Yorum Ekle
  25. LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: adım 25, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: adım 25, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: adım 25, 3 resimden 3.
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
    FixBot'a Sor
    Yorum Ekle
  26. LG Front Load Washing Machine Pump Assembly Replacement: adım 26, 1 resimden 1.
    • Remove the front panel.
    FixBot'a Sor
    Yorum Ekle
  27. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: adım 27, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: adım 27, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: adım 27, 3 resimden 3.
    • Twist and remove the pump filter.
    FixBot'a Sor
    Yorum Ekle
  28. LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: adım 28, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: adım 28, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: adım 28, 3 resimden 3.
    • Push the drain hose through its hole in the chassis until it's completely inside the device.
    FixBot'a Sor
    Yorum Ekle
  29. LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: adım 29, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: adım 29, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: adım 29, 3 resimden 3.
    • Use diagonal cutters, or scissors, to remove any cable ties securing the plastic wrap on the pump assembly cable connector(s).
    FixBot'a Sor
    Yorum Ekle
  30. LG Front Load Washing Machine Pump Assembly Replacement: adım 30, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement: adım 30, 2 resimden 2.
    • Fold the plastic wrap away from the cables, enough to expose the connector(s).
    • During reassembly, replace the cable ties to ensure a water-tight fit for the plastic wrap.
    FixBot'a Sor
    Yorum Ekle
  31. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: adım 31, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: adım 31, 2 resimden 2.
    • Disconnect the connector(s) attached to the pump cable.
    FixBot'a Sor
    Yorum Ekle
  32. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: adım 32, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: adım 32, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: adım 32, 3 resimden 3.
    • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
    FixBot'a Sor
    Yorum Ekle
  33. LG Front Load Washing Machine Pump Assembly Replacement: adım 33, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement: adım 33, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement: adım 33, 3 resimden 3.
    • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
    • Pull the drain hose straight off its connection on the assembly.
    FixBot'a Sor
    Yorum Ekle
  34. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: adım 34, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: adım 34, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: adım 34, 3 resimden 3.
    • Repeat the last two steps for the pump hose.
    FixBot'a Sor
    Yorum Ekle
  35. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: adım 35, 2 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: adım 35, 2 resimden 2.
    • Remove the screw(s) securing the pump assembly to the bottom lip of the washer.
    FixBot'a Sor
    Yorum Ekle
  36. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: adım 36, 3 resimden 1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: adım 36, 3 resimden 2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: adım 36, 3 resimden 3.
    • Lift the pump assembly out of its location in the frame to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
4 farklı kişi bu kılavuzu tamamladı.
Bill Gilbert
39.917 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.572 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hi Bill, Fantastic instructions - thanks for taking the time to put these together!
Ken Adams - Yanıt Paylaş
Wow, that's intense. I wonder if I can just prop it up and get to that pump from the bottom? I don't have a jack stand or anything but I saw someone lean it back into a metal step stool.
Doyle Stadt - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 56
Son 30 gün: 187
Her zaman: 4,963
