Ana içeriğe geç
LG Front Load Washing Machine Rotor Replacement
Neye ihtiyacın var
    1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: adım 1, 2 resimden 1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: adım 1, 2 resimden 2.
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
      • Remove the screw(s) securing the rear panel.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: adım 3, 3 resimden 1. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: adım 3, 3 resimden 2. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: adım 3, 3 resimden 3.
      • Unclip the rear panel from the chassis.
      FixBot'a Sor
      Yorum Ekle
    3. LG Front Load Washing Machine Rotor Replacement: adım 4, 1 resimden 1.
      • Remove the rear panel.
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: adım 5, 2 resimden 1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: adım 5, 2 resimden 2.
      • Use an impact driver to remove the 17 mm nut securing the rotor.
      • Alternatively, you can use a wrench and a hammer to loosen the nut.
      • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: adım 6, 2 resimden 1. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: adım 6, 2 resimden 2.
      • The rotor is magnetically attracted to the stator.
      • Pull the rotor straight off the stator and drive shaft splines to remove it.
      • Wiggle the rotor as you pull to help disconnect it.
      • This may require significant force.
      • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
Bill Gilbert
40.177 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
63.128 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 110
Her zaman: 2,374
