Ana içeriğe geç
LG G Watch Display Assembly Replacement
Mandy McGarry
Mandy McGarry ve 3 diğer katkıda bulunanlar
En son June 11, 2015 tarihinde güncellendi
15 dakika
Orta
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. LG G Watch Display Assembly Replacement, Wristband: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
    Is there a reason you are removing the straps before the back of the watch? They don't block the back from coming off or really get in the way much.
    Andy Wickham - Yanıt
    its in the way, obviously it need to take them off, lol.
    silentg4real -
    Where can I get this battery?
    Josh Wheat - Yanıt
    where can i buy a new replacement rear case? please let me know!
    silentg4real - Yanıt
    I'd like to know as well and don't care if it's a knock off either
    Joseph Wellman -
  2. LG G Watch Display Assembly Replacement: adım 2, 2 resimden 1. LG G Watch Display Assembly Replacement: adım 2, 2 resimden 2.
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Display Assembly Replacement, Rear Case: adım 3, 1 resimden 1.
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Display Assembly Replacement: adım 4, 2 resimden 1. LG G Watch Display Assembly Replacement: adım 4, 2 resimden 2.
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Display Assembly Replacement, Gasket: adım 5, 1 resimden 1.
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  6. LG G Watch Display Assembly Replacement, Motherboard: adım 6, 2 resimden 1. LG G Watch Display Assembly Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
  7. LG G Watch Display Assembly Replacement: adım 7, 2 resimden 1. LG G Watch Display Assembly Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
  8. LG G Watch Display Assembly Replacement, Removing the screen: adım 8, 1 resimden 1.
    • Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
    • Gently work the pick around the perimeter of the device to loosen up the adhesive.
    • An iOpener may be necessary to help loosen up the adhesive. Refer to our iOpener guide for info on how to use it.
  9. LG G Watch Display Assembly Replacement: adım 9, 2 resimden 1. LG G Watch Display Assembly Replacement: adım 9, 2 resimden 2.
    • After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mandy McGarry
165 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Blackwell Fall 2014 USF Tampa, Team 2-5, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G5
5 Üyeler
9 adet Kılavuz yazıldı
4Kılavuz Yorumları
Where can you purchase replacement parts?
Brian Winebarger - Yanıt
Someone knows where to find a screen replacement?, i found at alibaba but i have to buy 1k ... :(
George Momo Seyssel - Yanıt
I found a 00 screwdriver was better than 000 for removing the motherboard.
Peter Jeremy - Yanıt
Be smart buy a used one for nuthin on eBay….
jeromedaues - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 4,442
