Ana içeriğe geç
LG G Watch R Motherboard Replacement
Neye ihtiyacın var
  1. LG G Watch R Motherboard Replacement, Back Case: adım 1, 2 resimden 1. LG G Watch R Motherboard Replacement, Back Case: adım 1, 2 resimden 2.
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
    FixBot'a Sor
  2. LG G Watch R Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
    FixBot'a Sor
  3. LG G Watch R Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the back case.
    FixBot'a Sor
  4. LG G Watch R Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. LG G Watch R Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
    FixBot'a Sor
  5. LG G Watch R Motherboard Replacement: adım 5, 2 resimden 1. LG G Watch R Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
    FixBot'a Sor
  6. LG G Watch R Motherboard Replacement: adım 6, 1 resimden 1.
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
    FixBot'a Sor
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Westley Courchene
3.410 İtibar
14 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G1
5 Üyeler
3Kılavuz Yorumları
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - Yanıt Paylaş
Where do I buy a replacement motherboard from??
Brandon Reznik - Yanıt Paylaş
Did you ever find anywhere to order a replacement motherboard?
Robert Dye - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 102
Her zaman: 3,910
