Ana içeriğe geç
LG G2 mini LTE LCD Replacement
Aung Myin Thu Mayet
Aung Myin Thu Mayet ve 2 diğer katkıda bulunanlar
En son January 10, 2015 tarihinde güncellendi
30 dakika - 1 saat
Çok zor
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. LG G2 mini LTE LCD Replacement, Remove the Battery Cover: adım 1, 1 resimden 1.
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily
  2. LG G2 mini LTE LCD Replacement, Remove the Battery: adım 2, 1 resimden 1.
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  3. LG G2 mini LTE LCD Replacement, Unscrew the Motherboard Cover: adım 3, 2 resimden 1. LG G2 mini LTE LCD Replacement, Unscrew the Motherboard Cover: adım 3, 2 resimden 2.
    • Locate 10 screws and remove each one using a screw driver
  4. LG G2 mini LTE LCD Replacement, Remove the Motherboard Cover: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry away the cover by placing it between the cover and the screen bezel.
    • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
  5. LG G2 mini LTE LCD Replacement, Remove the Rear Facing Camera: adım 5, 3 resimden 1. LG G2 mini LTE LCD Replacement, Remove the Rear Facing Camera: adım 5, 3 resimden 2. LG G2 mini LTE LCD Replacement, Remove the Rear Facing Camera: adım 5, 3 resimden 3.
    • Locate the rear facing camera.
    • Pry the ribbon cable off of it's connector using the plastic spudger tool.
    • Use your finger to remove the camera.
  6. LG G2 mini LTE LCD Replacement, Remove the Front Facing Camera: adım 6, 3 resimden 1. LG G2 mini LTE LCD Replacement, Remove the Front Facing Camera: adım 6, 3 resimden 2. LG G2 mini LTE LCD Replacement, Remove the Front Facing Camera: adım 6, 3 resimden 3.
    • Locate the front facing camera.
  7. LG G2 mini LTE LCD Replacement, Detach the Digitizer and LCD Ribbon Cables: adım 7, 3 resimden 1. LG G2 mini LTE LCD Replacement, Detach the Digitizer and LCD Ribbon Cables: adım 7, 3 resimden 2. LG G2 mini LTE LCD Replacement, Detach the Digitizer and LCD Ribbon Cables: adım 7, 3 resimden 3.
    • Use the plastic spudger tool or a flat head screwdriver to pry the ribbon cables off of their connectors.
  8. LG G2 mini LTE LCD Replacement, Remove the Motherboard: adım 8, 1 resimden 1.
    • Use your finger to lift the motherboard from the edge and remove it from the phone.
  9. LG G2 mini LTE LCD Replacement, Remove the Cable Security Tape: adım 9, 2 resimden 1. LG G2 mini LTE LCD Replacement, Remove the Cable Security Tape: adım 9, 2 resimden 2.
    • Pull from the tabs on the edges of the security tape.
    • This piece is not absolutely necessary to replace when putting the phone back together, but it secures the cables against movement from day to day activities. If you have some electrical tape lying around, use it to secure the cables during the process of putting the phone back together.
  10. LG G2 mini LTE LCD Replacement, Unstick the LCD Cable: adım 10, 2 resimden 1. LG G2 mini LTE LCD Replacement, Unstick the LCD Cable: adım 10, 2 resimden 2.
    • Peel the LCD cable off of the phone.
  11. LG G2 mini LTE LCD Replacement, Unstick the Glass Screen: adım 11, 2 resimden 1. LG G2 mini LTE LCD Replacement, Unstick the Glass Screen: adım 11, 2 resimden 2.
    • Use a heat gun to heat the edges of the LCD screen and melt the adhesive that holds the glass on.
    • Pry the edges of the glass away from the phone using a plastic spudger tool. Do this quickly before the glass cools down and starts to stick again.
    • The glass will get very hot. Take care not to burn yourself when touching it.
  12. LG G2 mini LTE LCD Replacement, Remove the Glass Screen: adım 12, 3 resimden 1. LG G2 mini LTE LCD Replacement, Remove the Glass Screen: adım 12, 3 resimden 2. LG G2 mini LTE LCD Replacement, Remove the Glass Screen: adım 12, 3 resimden 3.
    • Push the ribbon cable connected to the Digitizer through the hole in the case and then pull the glass screen away from the phone.
  13. LG G2 mini LTE LCD Replacement, Remove the LCD Screen: adım 13, 3 resimden 1. LG G2 mini LTE LCD Replacement, Remove the LCD Screen: adım 13, 3 resimden 2. LG G2 mini LTE LCD Replacement, Remove the LCD Screen: adım 13, 3 resimden 3.
    • Push the ribbon cable connected to the LCD screen through the hole in the case.
    • Pull the LCD screen away from the case.
    • At this point you are ready to replace the LCD with a working one.
  14. LG G2 mini LTE LCD Replacement, Making the Glass Screen Stick Again: adım 14, 2 resimden 1. LG G2 mini LTE LCD Replacement, Making the Glass Screen Stick Again: adım 14, 2 resimden 2.
    • If you bought a full LCD and Digitizer assembly, then you can discard the old Digitizer and just replace it with the new one. If you only bought the LCD component and would like to reuse the current digitizer then follow the steps below.
    • Peel off the excess adhesive from the bezel of the glass screen.
    • Line the bezel of the glass screen with 3M double sided adhesive tape. You will be able to stick it back on easily.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Aung Myin Thu Mayet
653 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-9, Shastany Fall 2014 UMass Dartmouth, Team 1-9, Shastany Fall 2014 üyesi
UMASSD-SHASTANY-F14S1G9
3 Üyeler
9 adet Kılavuz yazıldı
3Kılavuz Yorumları
It is possible to change only digitizer? It seems glued or fused to LCD by a whole surface...
kapr73 - Yanıt
yes, it is glued and can be removed by heat
Elliott -
Great article, I could change my digitizer successfully.
Respect.
Fran Hdez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 12,079
