Ana içeriğe geç
LG G5 Battery Replacement
Neye ihtiyacın var
  1. LG G5 Battery Replacement, Battery: adım 1, 3 resimden 1. LG G5 Battery Replacement, Battery: adım 1, 3 resimden 2. LG G5 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
    FixBot'a Sor
    Yorum Ekle
  2. LG G5 Battery Replacement: adım 2, 2 resimden 1. LG G5 Battery Replacement: adım 2, 2 resimden 2.
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
    FixBot'a Sor
    Yorum Ekle
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.704 İtibar
538 adet Kılavuz yazıldı
4Kılavuz Yorumları
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Yanıt Paylaş
Was machen wenn Akku Snap In ab ist?
Ra Ku - Yanıt Paylaş
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 123
Her zaman: 17,707
