Ana içeriğe geç
LG L1200 Inner LCD Screen Replacement
Joshua Herrmann
Joshua Herrmann ve 5 diğer katkıda bulunanlar
En son January 19, 2018 tarihinde güncellendi
20 dakika
Orta
This guide will help you replace the inner LCD screen if broken or in need of repair.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. LG L1200 Inner LCD Screen Replacement, Inner LCD Screen: adım 1, 1 resimden 1.
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Inner LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Inner LCD Screen Replacement: adım 3, 1 resimden 1.
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Inner LCD Screen Replacement: adım 4, 3 resimden 1. LG L1200 Inner LCD Screen Replacement: adım 4, 3 resimden 2. LG L1200 Inner LCD Screen Replacement: adım 4, 3 resimden 3.
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Inner LCD Screen Replacement: adım 5, 2 resimden 1. LG L1200 Inner LCD Screen Replacement: adım 5, 2 resimden 2.
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Inner LCD Screen Replacement: adım 6, 1 resimden 1.
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Inner LCD Screen Replacement: adım 7, 3 resimden 1. LG L1200 Inner LCD Screen Replacement: adım 7, 3 resimden 2. LG L1200 Inner LCD Screen Replacement: adım 7, 3 resimden 3.
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Inner LCD Screen Replacement: adım 8, 3 resimden 1. LG L1200 Inner LCD Screen Replacement: adım 8, 3 resimden 2. LG L1200 Inner LCD Screen Replacement: adım 8, 3 resimden 3.
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Inner LCD Screen Replacement: adım 9, 2 resimden 1. LG L1200 Inner LCD Screen Replacement: adım 9, 2 resimden 2.
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Inner LCD Screen Replacement: adım 10, 2 resimden 1. LG L1200 Inner LCD Screen Replacement: adım 10, 2 resimden 2.
    • Use the spudger to remove the LCD screen from its backing.
Sonuç
Joshua Herrmann
8 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G14
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 2,249
