Ana içeriğe geç
LG Optimus L7 P705 Display Replacement
Neye ihtiyacın var
  1. LG Optimus L7 P705 Display Replacement, Display: adım 1, 2 resimden 1. LG Optimus L7 P705 Display Replacement, Display: adım 1, 2 resimden 2.
    • Use a plastic opening tool to gently pry the back cover away from the phone by inserting it into the seam around the edges.
    • Once the cover is off, remove the battery and SIM card.
    FixBot'a Sor
    Yorum Ekle
  2. LG Optimus L7 P705 Display Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the twelve 3mm screws around the frame, including those near the SIM and SD card slots.
    FixBot'a Sor
    Yorum Ekle
  3. LG Optimus L7 P705 Display Replacement: adım 3, 1 resimden 1.
    • Carefully remove the bottom plastic plate located around the charging port area.
    FixBot'a Sor
    Yorum Ekle
  4. LG Optimus L7 P705 Display Replacement: adım 4, 2 resimden 1. LG Optimus L7 P705 Display Replacement: adım 4, 2 resimden 2.
    • Insert a plastic opening tool along the seam of the phone’s frame and gently apply pressure to lift off the midframe cover.
    FixBot'a Sor
    Yorum Ekle
  5. LG Optimus L7 P705 Display Replacement: adım 5, 2 resimden 1. LG Optimus L7 P705 Display Replacement: adım 5, 2 resimden 2.
    • Flip the phone over so the screen is facing up.
    • Carefully lift and remove the glass screen (display) from the front of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
8 farklı kişi bu kılavuzu tamamladı.
Craig Lashley
307 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Leahy Fall 2014 USF Tampa, Team 9-1, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S9G1
3 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Sooty - Yanıt Paylaş
Im miles i great this ifixit i'm beginner
Omair Sarip - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 5,716
