Ana içeriğe geç
LG Phoenix 2 Charge Port Replacement
Neye ihtiyacın var
  1. LG Phoenix 2 Charge Port Replacement, Battery: adım 1, 3 resimden 1. LG Phoenix 2 Charge Port Replacement, Battery: adım 1, 3 resimden 2. LG Phoenix 2 Charge Port Replacement, Battery: adım 1, 3 resimden 3.
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Charge Port Replacement: adım 2, 3 resimden 1. LG Phoenix 2 Charge Port Replacement: adım 2, 3 resimden 2. LG Phoenix 2 Charge Port Replacement: adım 2, 3 resimden 3.
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Charge Port Replacement, Motherboard: adım 3, 2 resimden 1. LG Phoenix 2 Charge Port Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
  4. LG Phoenix 2 Charge Port Replacement: adım 4, 2 resimden 1. LG Phoenix 2 Charge Port Replacement: adım 4, 2 resimden 2.
    • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
  5. LG Phoenix 2 Charge Port Replacement: adım 5, 3 resimden 1. LG Phoenix 2 Charge Port Replacement: adım 5, 3 resimden 2. LG Phoenix 2 Charge Port Replacement: adım 5, 3 resimden 3.
    • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
  6. LG Phoenix 2 Charge Port Replacement: adım 6, 3 resimden 1. LG Phoenix 2 Charge Port Replacement: adım 6, 3 resimden 2. LG Phoenix 2 Charge Port Replacement: adım 6, 3 resimden 3.
    • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
  7. LG Phoenix 2 Charge Port Replacement, Charge Port: adım 7, 2 resimden 1. LG Phoenix 2 Charge Port Replacement, Charge Port: adım 7, 2 resimden 2.
  8. LG Phoenix 2 Charge Port Replacement: adım 8, 3 resimden 1. LG Phoenix 2 Charge Port Replacement: adım 8, 3 resimden 2. LG Phoenix 2 Charge Port Replacement: adım 8, 3 resimden 3.
    • Desolder the USB port from the motherboard and remove it from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alex Selsley
325 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Harley Fall 2019 IUPUI, Team S1-G1, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S1G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 700
