Ana içeriğe geç
LG Refrigerator Condenser Fan Motor Replacement
Neye ihtiyacın var
    1. LG Refrigerator Condenser Fan Motor Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      FixBot'a Sor
      Yorum Ekle
    1. LG Refrigerator Condenser Fan Motor Replacement, Unfasten the condenser cover: adım 2, 1 resimden 1.
      • Use a Phillips screwdriver to remove the screws securing the condenser cover to the rear of the refrigerator.
      FixBot'a Sor
      Yorum Ekle
    2. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: adım 3, 3 resimden 1. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: adım 3, 3 resimden 2. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: adım 3, 3 resimden 3.
      • Tilt the top edge of the condenser cover toward you.
      • Lift and remove the condenser cover.
      FixBot'a Sor
      Yorum Ekle
    1. LG Refrigerator Condenser Fan Motor Replacement, Disconnect the condenser fan: adım 4, 2 resimden 1. LG Refrigerator Condenser Fan Motor Replacement, Disconnect the condenser fan: adım 4, 2 resimden 2.
      • Squeeze and pull the condenser fan connector straight down to disconnect the condenser fan.
      FixBot'a Sor
      Yorum Ekle
    2. LG Refrigerator Condenser Fan Motor Replacement, Unfasten the condenser fan shroud: adım 5, 1 resimden 1.
      • Use a Phillips screwdriver to remove the condenser fan shroud screw.
      FixBot'a Sor
      Yorum Ekle
    3. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: adım 6, 3 resimden 1. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: adım 6, 3 resimden 2. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: adım 6, 3 resimden 3.
      • Place a pair of slip joint pliers around the condenser fan drive shaft.
      • Place a large flat blade screwdriver between the slip joint pliers and the fan hub.
      • While holding the pliers in place, push the screwdriver against the pliers to pry the fan off.
      FixBot'a Sor
      Yorum Ekle
    4. LG Refrigerator Condenser Fan Motor Replacement: adım 7, 2 resimden 1. LG Refrigerator Condenser Fan Motor Replacement: adım 7, 2 resimden 2.
      • Remove the fan blade assembly.
      FixBot'a Sor
      Yorum Ekle
    5. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: adım 8, 3 resimden 1. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: adım 8, 3 resimden 2. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: adım 8, 3 resimden 3.
      • Use a stubby Phillips screwdriver to remove the screws securing the fan motor inside the fan motor bracket.
      • You may find it easier to use a 1/4 inch drive socket with a Phillips head bit to remove the screws.
      FixBot'a Sor
      Yorum Ekle
    6. LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: adım 9, 3 resimden 1. LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: adım 9, 3 resimden 2. LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: adım 9, 3 resimden 3.
      • Push apart the two halves of the fan motor bracket to release the fan motor.
      • Slide the fan motor shaft up through the slot in the front fan motor bracket.
      FixBot'a Sor
      Yorum Ekle
    7. LG Refrigerator Condenser Fan Motor Replacement: adım 10, 2 resimden 1. LG Refrigerator Condenser Fan Motor Replacement: adım 10, 2 resimden 2.
      • Remove the fan motor.
      FixBot'a Sor
      Yorum Ekle
    8. LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: adım 11, 3 resimden 1. LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: adım 11, 3 resimden 2. LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: adım 11, 3 resimden 3.
      • Transfer the two rubber motor mounting washers from the old motor to the new motor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
40.159 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
34.678 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 91
Son 30 gün: 279
Her zaman: 6,350
