Ana içeriğe geç
LG Refrigerator Control Board Replacement
Neye ihtiyacın var
    1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      FixBot'a Sor
      Yorum Ekle
    1. LG Refrigerator Control Board Replacement, Unfasten the control board cover: adım 2, 1 resimden 1.
      • Use a Phillips screwdriver to remove the screws securing the control board cover.
      FixBot'a Sor
      Yorum Ekle
    2. LG Refrigerator Control Board Replacement, Remove the control board cover: adım 3, 3 resimden 1. LG Refrigerator Control Board Replacement, Remove the control board cover: adım 3, 3 resimden 2. LG Refrigerator Control Board Replacement, Remove the control board cover: adım 3, 3 resimden 3.
      • Tilt the top edge of the cover toward you and lift it off.
      FixBot'a Sor
      Yorum Ekle
    1. LG Refrigerator Control Board Replacement, Disconnect the control board: adım 4, 3 resimden 1. LG Refrigerator Control Board Replacement, Disconnect the control board: adım 4, 3 resimden 2. LG Refrigerator Control Board Replacement, Disconnect the control board: adım 4, 3 resimden 3.
      • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
      • Squeeze and pull the connectors to disconnect them from the control board.
      • Make sure to fully reconnect each connector when reassembling.
      FixBot'a Sor
      Yorum Ekle
    2. LG Refrigerator Control Board Replacement, Release the control board: adım 5, 3 resimden 1. LG Refrigerator Control Board Replacement, Release the control board: adım 5, 3 resimden 2. LG Refrigerator Control Board Replacement, Release the control board: adım 5, 3 resimden 3.
      • Use your thumb to pry up and release the top left retaining clip securing the control board.
      • With your other hand, pull the top left corner of the control board out to loosen it.
      FixBot'a Sor
      Yorum Ekle
    3. LG Refrigerator Control Board Replacement: adım 6, 3 resimden 1. LG Refrigerator Control Board Replacement: adım 6, 3 resimden 2. LG Refrigerator Control Board Replacement: adım 6, 3 resimden 3.
      • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
      FixBot'a Sor
      Yorum Ekle
    4. LG Refrigerator Control Board Replacement, Remove the control board: adım 7, 1 resimden 1.
      • Lift the control board out by its edges and remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
4 farklı kişi bu kılavuzu tamamladı.
Bill Gilbert
40.177 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
63.128 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 69
Son 30 gün: 276
Her zaman: 5,061
