Giriş
Use this guide to remove the freezer light on your LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The freezer light allows you to see the contents of the freezer drawer more easily.
Neye ihtiyacın var
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Lift and remove the upper pull-out drawer.
Lift and remove the main drawer bin.
Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
Lift the cover off of the rail and remove it.
Repeat this procedure for the left drawer rail cover.
Hold the drawer rail cover flush against the side of the drawer rail.
Push the rail cover straight downward to install. It should click into place.
Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
Use a Phillips screwdriver to remove the screw(s) securing the freezer light.
Lower the front edge of the freezer light to access its connector.
Squeeze the freezer light connector and pull it straight off to disconnect it.
Remove the freezer light.
1Rehber Yorum
Do you know the part number and where to get it? Thanks, very good video.
