Ana içeriğe geç
LG Refrigerator Ice Dispensing Switch Testing and Replacement
Neye ihtiyacın var
  1. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Loosen the left door handle set screws: adım 2, 2 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Loosen the left door handle set screws: adım 2, 2 resimden 2.
    • To remove the left door handle, first open the right door.
    • Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
  3. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Remove the left door handle: adım 3, 2 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Remove the left door handle: adım 3, 2 resimden 2.
    • Pull the left door handle straight off to remove it.
  4. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Retaining clip locations: adım 4, 3 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Retaining clip locations: adım 4, 3 resimden 2. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Retaining clip locations: adım 4, 3 resimden 3.
    • The dispenser assembly is secured by very strong clips, making it very difficult to remove. Take note of the clip location examples shown in the photos:
    • Right side clips
    • Top clips
    • Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
    • During disassembly, you may break some of these clips. If you do, don't worry; the assembly does not need all the clips to be properly secured.
  5. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Release the dispenser: adım 5, 3 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Release the dispenser: adım 5, 3 resimden 2. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Release the dispenser: adım 5, 3 resimden 3.
    • Use a spudger to pry out the top edge of the dispenser assembly.
    • Once you've created a gap, use your fingertips to pull the edge downward.
    • Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
    • Optionally, you may use a flat-blade screwdriver to assist in this process. Be careful not to damage the door; you may scratch the door surface or dent the rim of the dispenser opening.
  6. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Reposition the dispenser: adım 6, 3 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Reposition the dispenser: adım 6, 3 resimden 2. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Reposition the dispenser: adım 6, 3 resimden 3.
    • Grasp the top edge of the dispenser assembly in the middle and pull outwards.
    • Continue prying and pulling around the perimeter of the assembly to release it.
  7. LG Refrigerator Ice Dispensing Switch Testing and Replacement: adım 7, 3 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement: adım 7, 3 resimden 2. LG Refrigerator Ice Dispensing Switch Testing and Replacement: adım 7, 3 resimden 3.
    • Grasp the assembly firmly and pull it out of the refrigerator door.
    • Don't try to pull the assembly completely off the refrigerator door. The assembly is still connected with numerous wires. These are mainly connected to the left side of the dispenser.
  8. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Disconnect the dispenser: adım 8, 1 resimden 1.
    • Squeeze the multiple wire connectors and pull them straight off to disconnect them from the various PC boards.
    • Some of the connectors may be permanently attached to the PC board and can't be removed.
  9. LG Refrigerator Ice Dispensing Switch Testing and Replacement: adım 9, 2 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement: adım 9, 2 resimden 2.
    • Squeeze and separate the various connectors in the wiring harness. The photo shows two examples.
  10. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: adım 10, 3 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: adım 10, 3 resimden 2. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: adım 10, 3 resimden 3.
    • Use a Phillips screwdriver to remove the screw securing the circuit board holder to the dispenser assembly. Many, but not all, units will have this PC board and holder.
    • Lift and remove the circuit board holder from the dispenser assembly.
  11. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Remove the dispenser: adım 11, 1 resimden 1.
    • You can now remove the dispenser from the refrigerator.
    • The circuit board holder, if present, can be suspended from the harness wires, as its weight is minimal.
  12. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Test the ice dispensing switch: adım 12, 2 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Test the ice dispensing switch: adım 12, 2 resimden 2.
    • If you have a multimeter, you can test to see if your ice dispensing switch is good or not.
    • Set your multimeter to the continuity function with beeper.
    • Touch one probe to each of the switch terminals at the same time.
    • Use your finger to press the operating lever connected to the switch; the meter should sound and read 1Ω or less.
    • Release the lever, and the meter should not sound and should read OL for open loop.
    • If the switch does not operate as described in the steps above, follow the next steps to replace it.
  13. LG Refrigerator Ice Dispensing Switch Testing and Replacement, Replace the ice dispensing switch: adım 13, 1 resimden 1.
    • Use a Phillips screwdriver to remove the screw(s) securing the ice dispensing switch to the dispenser assembly.
  14. LG Refrigerator Ice Dispensing Switch Testing and Replacement: adım 14, 2 resimden 1. LG Refrigerator Ice Dispensing Switch Testing and Replacement: adım 14, 2 resimden 2.
    • Lift the ice dispensing switch off the peg, and remove it.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
38.497 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.608 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 43
Her zaman: 939
