Ana içeriğe geç
LG VS810 Screen Replacement
[deleted]
[deleted] ve 4 diğer katkıda bulunanlar
En son January 18, 2022 tarihinde güncellendi
Tahmin yok
Orta
Daha Fazla Görsel Gerekli
Topluluk-Katkılı Kılavuz
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
    • Remove the back cover
    • Remove the battery , SIM card, and SD card
    • Unscrew the 8 screws using a Phillips (PH#00) screwdriver
    • Using a plastic opening tool , once again pry up on the edges of the plastic back cover.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced
    • Gently disconect the screen cable using a spudger.
    • Using the spudger, pry the motherboard away from the screen assembly.
    • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
    • Continue to heat and separate until the screen comes completely apart from the rest of the phone using plastic tools
    • The phone will be extremely hot. Avoid direct contact with metal pieces.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
[deleted]
422 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Pls help how can I fix lg-k120e screen
drammehoumar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 4,558
