Ana içeriğe geç
LG VX7000 Internal LCD Screen Replacement
Nichole Shaw
Nichole Shaw ve 2 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 - 30 dakika
Orta
Eksik önkoşulları
Replace a cracked internal LCD display.
Note: to replace the internal display, you must replace the entire face plate, not just the plastic screen.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: adım 2, 1 resimden 1.
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: adım 3, 1 resimden 1.
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: adım 4, 1 resimden 1.
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: adım 5, 1 resimden 1.
    • Align new face plate in correct orientation in order to install.
Sonuç
Nichole Shaw
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G75
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 2,265
