Giriş
This guide shows the process of repairing a Laser X 88016 that does not have operable flashing LED lights when powered on, nor when in use. The three LED wires soldered to the circuit board for these laser guns can easily detach, as these laser guns are operated in rigorous competition between both kids and adults. Caution: the ability to properly operate a soldering iron is necessary to complete this repair. If you are uncertain of how to properly operate a soldering iron, please refer to the following link: How To Solder and Desolder Connections. This guide will demonstrate how to render the LED lights of the Laser X 88016 operable again and how to disassemble the receiver in which the circuit board for the LED lights reside.
Neye ihtiyacın var
Using a Phillips #0 screwdriver, remove the one 9.6 mm screw from the bottom of the laser gun and pull off the battery cover.
Remove the three AAA batteries.
