Ana içeriğe geç
Lasko CD08200 Control Panel Replacement
Neye ihtiyacın var
  1. Lasko CD08200 Control Panel Replacement, Lasko CD08200 Disassembly: adım 1, 2 resimden 1. Lasko CD08200 Control Panel Replacement, Lasko CD08200 Disassembly: adım 1, 2 resimden 2.
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Lasko CD08200 Control Panel Replacement: adım 2, 1 resimden 1.
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
    FixBot'a Sor
    Yorum Ekle
  3. Lasko CD08200 Control Panel Replacement: adım 3, 3 resimden 1. Lasko CD08200 Control Panel Replacement: adım 3, 3 resimden 2. Lasko CD08200 Control Panel Replacement: adım 3, 3 resimden 3.
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Lasko CD08200 Control Panel Replacement: adım 4, 3 resimden 1. Lasko CD08200 Control Panel Replacement: adım 4, 3 resimden 2. Lasko CD08200 Control Panel Replacement: adım 4, 3 resimden 3.
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
    FixBot'a Sor
    Yorum Ekle
  5. Lasko CD08200 Control Panel Replacement, Control Panel: adım 5, 2 resimden 1. Lasko CD08200 Control Panel Replacement, Control Panel: adım 5, 2 resimden 2.
    • Unscrew the four rings using the Phillips #2.
    • Gently remove the fan base from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Lasko CD08200 Control Panel Replacement: adım 6, 3 resimden 1. Lasko CD08200 Control Panel Replacement: adım 6, 3 resimden 2. Lasko CD08200 Control Panel Replacement: adım 6, 3 resimden 3.
    • Remove the four 14mm screws using the Phillips #2 screwdriver.
    • Gently detach the control panel from the device.
    FixBot'a Sor
    Yorum Ekle
  7. Lasko CD08200 Control Panel Replacement: adım 7, 2 resimden 1. Lasko CD08200 Control Panel Replacement: adım 7, 2 resimden 2.
    • Remove the five 14mm screws using the Phillips #2 screwdriver.
    • Pull apart the motherboard from the panel.
    FixBot'a Sor
    Yorum Ekle
  8. Lasko CD08200 Control Panel Replacement: adım 8, 3 resimden 1. Lasko CD08200 Control Panel Replacement: adım 8, 3 resimden 2. Lasko CD08200 Control Panel Replacement: adım 8, 3 resimden 3.
    • Remove the three 10mm screws using the Phillips #2 screwdriver.
    • Pull the button from the panel’s top.
    • During reassembly of the top panel, you must align the LED light with the three windows of the top panel and back panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Najiib Ahmed
161 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 1,157
