Ana içeriğe geç
Lasko CD08200 Disassembly
Neye ihtiyacın var
  1. Lasko CD08200 Disassembly, Lasko CD08200 Disassembly: adım 1, 2 resimden 1. Lasko CD08200 Disassembly, Lasko CD08200 Disassembly: adım 1, 2 resimden 2.
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 Disassembly: adım 2, 1 resimden 1.
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 Disassembly: adım 3, 3 resimden 1. Lasko CD08200 Disassembly: adım 3, 3 resimden 2. Lasko CD08200 Disassembly: adım 3, 3 resimden 3.
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
  4. Lasko CD08200 Disassembly: adım 4, 3 resimden 1. Lasko CD08200 Disassembly: adım 4, 3 resimden 2. Lasko CD08200 Disassembly: adım 4, 3 resimden 3.
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
Sonuç
Artur Komissarov
382 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 256
