Ana içeriğe geç
Lasko CD08200 Fan Replacement
Neye ihtiyacın var
  1. Lasko CD08200 Fan Replacement, Lasko CD08200 Disassembly: adım 1, 2 resimden 1. Lasko CD08200 Fan Replacement, Lasko CD08200 Disassembly: adım 1, 2 resimden 2.
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Lasko CD08200 Fan Replacement: adım 2, 1 resimden 1.
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
    FixBot'a Sor
    Yorum Ekle
  3. Lasko CD08200 Fan Replacement: adım 3, 3 resimden 1. Lasko CD08200 Fan Replacement: adım 3, 3 resimden 2. Lasko CD08200 Fan Replacement: adım 3, 3 resimden 3.
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Lasko CD08200 Fan Replacement: adım 4, 3 resimden 1. Lasko CD08200 Fan Replacement: adım 4, 3 resimden 2. Lasko CD08200 Fan Replacement: adım 4, 3 resimden 3.
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
    FixBot'a Sor
    Yorum Ekle
  5. Lasko CD08200 Fan Replacement, Fan: adım 5, 2 resimden 1. Lasko CD08200 Fan Replacement, Fan: adım 5, 2 resimden 2.
    • While holding onto the back of the fan housing with one hand and holding the center of the propeller, pull the propeller out.
    • During reassembly, push the propeller and red plate together into the metal shaft until you feel the plate click.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Yonatan Krapivsky
208 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,170
