Ana içeriğe geç
Lasko CD08200 Fuse Replacement
Neye ihtiyacın var
  1. Lasko CD08200 Fuse Replacement, Lasko CD08200 Disassembly: adım 1, 2 resimden 1. Lasko CD08200 Fuse Replacement, Lasko CD08200 Disassembly: adım 1, 2 resimden 2.
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Lasko CD08200 Fuse Replacement: adım 2, 1 resimden 1.
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
    FixBot'a Sor
    Yorum Ekle
  3. Lasko CD08200 Fuse Replacement: adım 3, 3 resimden 1. Lasko CD08200 Fuse Replacement: adım 3, 3 resimden 2. Lasko CD08200 Fuse Replacement: adım 3, 3 resimden 3.
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Lasko CD08200 Fuse Replacement: adım 4, 3 resimden 1. Lasko CD08200 Fuse Replacement: adım 4, 3 resimden 2. Lasko CD08200 Fuse Replacement: adım 4, 3 resimden 3.
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
    FixBot'a Sor
    Yorum Ekle
  5. Lasko CD08200 Fuse Replacement, Fuse: adım 5, 2 resimden 1. Lasko CD08200 Fuse Replacement, Fuse: adım 5, 2 resimden 2.
    • Remove the four 14mm screws housing the fan base using the Phillips #2 screwdriver.
    • Remove the fan base from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Lasko CD08200 Fuse Replacement: adım 6, 3 resimden 1. Lasko CD08200 Fuse Replacement: adım 6, 3 resimden 2. Lasko CD08200 Fuse Replacement: adım 6, 3 resimden 3.
    • Remove the four 14mm screws housing the top panel using the Phillips #2 screwdriver.
    • Remove the top panel from the device.
    FixBot'a Sor
    Yorum Ekle
  7. Lasko CD08200 Fuse Replacement: adım 7, 1 resimden 1.
    • Remove the four 14mm screws housing the motherboard to the top panel using the Phillips #2 screwdriver.
    • Remove the motherboard from the top panel.
    • When reassembling, align the mainboard to the legs of the front panel as shown in the images. Screw in the first screw in the center of the mainboard.
    FixBot'a Sor
    Yorum Ekle
  8. Lasko CD08200 Fuse Replacement: adım 8, 2 resimden 1. Lasko CD08200 Fuse Replacement: adım 8, 2 resimden 2.
    • Solder the two points on the back of the motherboard to release the fuse on the front.
    • Remove the fuse from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yonatan Krapivsky
208 İtibar
2 adet Kılavuz yazıldı
Ekip
3Kılavuz Yorumları
This is a very clearly written and beautifully photographed repair description. Thank you!
The only other information I need is a detailed description of the fuse so I can have a replacement ready to install when I begin the repair. Would you be willing to provide this information?
Thanks very much!
Jamie Wolf - Yanıt Paylaş
Salutations!
I'm afraid that neither I or my colleagues have no information on the fuse replaced on this guide. Perhaps an electrician with a careful eye may be able to help determine which fuse is required for this guide.
Best of luck on repairing your Lasko!
Artur Komissarov - Yanıt Paylaş
Thanks for your response and for your good wishes!
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 71
Her zaman: 7,176
