Ana içeriğe geç
LeapFrog Scribble and Write Speaker Replacement
Neye ihtiyacın var
  1. LeapFrog Scribble and Write Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Turn your toy over so that the back is facing upward.
  2. LeapFrog Scribble and Write Speaker Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #00 screwdriver, unscrew all circled areas.
  3. LeapFrog Scribble and Write Speaker Replacement: adım 3, 1 resimden 1.
    • Very carefully, remove the back case to reveal the contents of the toy.
  4. LeapFrog Scribble and Write Speaker Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the screw highlighted in the image.
  5. LeapFrog Scribble and Write Speaker Replacement: adım 5, 1 resimden 1.
    • Un-solder the wiring from the speaker and motherboard.
    • Caution: Be careful when using a soldering iron. Improper usage may result in burns.
Sonuç
Anthony Kidd
256 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 764
