Ana içeriğe geç
Leather Stitching Replacement
Neye ihtiyacın var
    1. Leather Stitching Replacement, Leather Stitching: adım 1, 3 resimden 1. Leather Stitching Replacement, Leather Stitching: adım 1, 3 resimden 2. Leather Stitching Replacement, Leather Stitching: adım 1, 3 resimden 3.
      • Using scissors, cut the thread at the seams.
      FixBot'a Sor
      Yorum Ekle
    2. Leather Stitching Replacement: adım 2, 3 resimden 1. Leather Stitching Replacement: adım 2, 3 resimden 2. Leather Stitching Replacement: adım 2, 3 resimden 3.
      • Take the thread out with your fingers.
      FixBot'a Sor
      Yorum Ekle
    3. Leather Stitching Replacement: adım 3, 2 resimden 1. Leather Stitching Replacement: adım 3, 2 resimden 2.
      • The new piece of leather thread should be three times the length of the stitch plus the length of the two needles.
      • Cut the thread.
      • Push one end of the thread through the eye of the needle.
      • Do the same for the other end, with the second needle.
      FixBot'a Sor
      Yorum Ekle
    4. Leather Stitching Replacement: adım 4, 3 resimden 1. Leather Stitching Replacement: adım 4, 3 resimden 2. Leather Stitching Replacement: adım 4, 3 resimden 3.
      • To tie the thread, bring the open end of the thread to the tip of the needle.
      • Push the needle all the way through the thread.
      • Pull the thread to secure the knot at the top.
      • You do not want a short end because the knot will come loose.
      FixBot'a Sor
      Yorum Ekle
    5. Leather Stitching Replacement: adım 5, 3 resimden 1. Leather Stitching Replacement: adım 5, 3 resimden 2. Leather Stitching Replacement: adım 5, 3 resimden 3.
      • Line up the first hole on both pieces.
      • Push one needle all the way through.
      • Pull till the length of the thread is equal on each side.
      FixBot'a Sor
      Yorum Ekle
    6. Leather Stitching Replacement: adım 6, 3 resimden 1. Leather Stitching Replacement: adım 6, 3 resimden 2. Leather Stitching Replacement: adım 6, 3 resimden 3.
      • You should have a needle on the right side of the leather and one on the left.
      • Push the right side needle through the second hole.
      • Push the left side need through the same hole.
      • Tug each side to tighten the stitch.
      • After tugging, you will end up having a needle on the right side and left side.
      FixBot'a Sor
      Yorum Ekle
    7. Leather Stitching Replacement: adım 7, 1 resimden 1.
      • With each hole, make sure both needles go through to the other side and are pulled together to tighten the stitch.
      • Continue this pattern until the end.
      FixBot'a Sor
      Yorum Ekle
    8. Leather Stitching Replacement: adım 8, 3 resimden 1. Leather Stitching Replacement: adım 8, 3 resimden 2. Leather Stitching Replacement: adım 8, 3 resimden 3.
      • To finish the stitch, we are going to push the needle into the second-to-last hole.
      • It should not pass through both pieces, only the one piece.
      • Do this for both sides.
      FixBot'a Sor
      Yorum Ekle
    9. Leather Stitching Replacement: adım 9, 3 resimden 1. Leather Stitching Replacement: adım 9, 3 resimden 2. Leather Stitching Replacement: adım 9, 3 resimden 3.
      • Tie the finishing knot by crossing the threads and pushing the needle through the made hole.
      • Pull to tighten and repeat once.
      FixBot'a Sor
      Yorum Ekle
    10. Leather Stitching Replacement: adım 10, 3 resimden 1. Leather Stitching Replacement: adım 10, 3 resimden 2. Leather Stitching Replacement: adım 10, 3 resimden 3.
      • Use the scissors to cut off the excess thread.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 85
Her zaman: 3,000
