Ana içeriğe geç
Lego Dimensions Starter Pack Motherboard Replacement
Neye ihtiyacın var
  1. Lego Dimensions Starter Pack Motherboard Replacement, Top Cover Parts: adım 1, 2 resimden 1. Lego Dimensions Starter Pack Motherboard Replacement, Top Cover Parts: adım 1, 2 resimden 2.
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack Motherboard Replacement: adım 2, 1 resimden 1.
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack Motherboard Replacement: adım 3, 1 resimden 1.
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack Motherboard Replacement: adım 5, 1 resimden 1.
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack Motherboard Replacement, USB Cable: adım 6, 1 resimden 1.
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
  7. Lego Dimensions Starter Pack Motherboard Replacement, LED Chip: adım 7, 1 resimden 1.
    • Pull the black connector of the ribbon away from the LED chip, keeping the connector parallel to the board.
    • Disconnect the connector on the other LED chip as well, if replacing both LED chips or the motherboard
  8. Lego Dimensions Starter Pack Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull the ribbon away from the black connector of the LED chips.
    • Disconnect the ribbon from the other LED chip as well, if replacing both LED chips or the motherboard.
  9. Lego Dimensions Starter Pack Motherboard Replacement: adım 9, 1 resimden 1.
    • Lift up both LED chips. As you are lifting, pull towards the motherboard to release it from the toy pad cover.
  10. Lego Dimensions Starter Pack Motherboard Replacement: adım 10, 1 resimden 1.
    • Lift up the motherboard, and remove the motherboard and LED chips from the toy pad.
  11. Lego Dimensions Starter Pack Motherboard Replacement: adım 11, 1 resimden 1.
    • Flip the motherboard and LED chips over.
    • Desolder the LED chip from the motherboard.
    • Desolder both LED chips, if replacing both LED chips or the motherboard
    • Separate the LED chip(s) from the motherboard.
    • Refer to this guide for soldering and desoldering tips.
  12. Lego Dimensions Starter Pack Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Separate the motherboard from both LED chips.
Sonuç
Alyssa Lach
509 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G2, Baechle Fall 2017 IUPUI, Team S5-G2, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S5G2
2 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 654
