Ana içeriğe geç
Lenovo G50-80 80E5 USB Port Replacement
Neye ihtiyacın var
  1. Lenovo G50-80 80E5 USB Port Replacement, Motherboard: adım 1, 2 resimden 1. Lenovo G50-80 80E5 USB Port Replacement, Motherboard: adım 1, 2 resimden 2.
    • From the underside of the laptop, press the two battery tabs inward to remove the battery. Lift the battery to remove.
  2. Lenovo G50-80 80E5 USB Port Replacement: adım 2, 2 resimden 1. Lenovo G50-80 80E5 USB Port Replacement: adım 2, 2 resimden 2.
    • Remove the three #00x5.5mm screws from the bottom front under panel and then slide the main access panel forward and out.
  3. Lenovo G50-80 80E5 USB Port Replacement: adım 3, 1 resimden 1.
    • Remove the two #00x4.5mm screws from the hard drive and then slide the drive to the side and remove the hard drive.
  4. Lenovo G50-80 80E5 USB Port Replacement: adım 4, 2 resimden 1. Lenovo G50-80 80E5 USB Port Replacement: adım 4, 2 resimden 2.
    • Remove the three #00x5.5mm screws from the fan unit, unplug the fan wiring connector and then remove the fan unit.
  5. Lenovo G50-80 80E5 USB Port Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to carefully remove the white and black wires from the WiFi card. Thread the wires back out of it's channel and hold to the side.
  6. Lenovo G50-80 80E5 USB Port Replacement: adım 6, 1 resimden 1.
    • Unplug the two ribbon cables from under the fan unit area.
  7. Lenovo G50-80 80E5 USB Port Replacement: adım 7, 2 resimden 1. Lenovo G50-80 80E5 USB Port Replacement: adım 7, 2 resimden 2.
    • Remove the CD Drive fixing screw (#00x5.5mm) and slide the drive out from it's slot.
  8. Lenovo G50-80 80E5 USB Port Replacement: adım 8, 3 resimden 1. Lenovo G50-80 80E5 USB Port Replacement: adım 8, 3 resimden 2. Lenovo G50-80 80E5 USB Port Replacement: adım 8, 3 resimden 3.
    • Release the RAM fixing clip from both ends of each RAM chip. Once released, slide out each RAM chip.
  9. Lenovo G50-80 80E5 USB Port Replacement: adım 9, 3 resimden 1. Lenovo G50-80 80E5 USB Port Replacement: adım 9, 3 resimden 2. Lenovo G50-80 80E5 USB Port Replacement: adım 9, 3 resimden 3.
    • Remove the three #00x5.5mm screws holding the keyboard.
  10. Lenovo G50-80 80E5 USB Port Replacement: adım 10, 1 resimden 1.
    • Remove the six perimeter #00x5.5mm screws holding the palm rest.
  11. Lenovo G50-80 80E5 USB Port Replacement: adım 11, 1 resimden 1.
    • Flip the laptop over, lift the screen and with a plastic spudger begin to remove the keyboard. Start at the top left corner and work from left to right lifting the keyboard. Once the top section is free, lift the keyboard up and away from yourself. Remove the ribbon cable connection and set the keyboard aside.
  12. Lenovo G50-80 80E5 USB Port Replacement: adım 12, 3 resimden 1. Lenovo G50-80 80E5 USB Port Replacement: adım 12, 3 resimden 2. Lenovo G50-80 80E5 USB Port Replacement: adım 12, 3 resimden 3.
    • Disconnect the two ribbon cables then using a plastic spudger, begin to separate the the palm rest from the chassis. Start along the front left edge and work left to right to separate each half. Separate the left and right sides in the same fashion.
  13. Lenovo G50-80 80E5 USB Port Replacement: adım 13, 2 resimden 1. Lenovo G50-80 80E5 USB Port Replacement: adım 13, 2 resimden 2.
    • Disconnect the CD Drive ribbon cable and the auxiliary board cable. Disconnect the speaker cable and then remove the CD Drive board fixing screw (#00x4.5mm). Remove the auxiliary board fixing screw and then remove the auxiliary board.
  14. Lenovo G50-80 80E5 USB Port Replacement: adım 14, 3 resimden 1. Lenovo G50-80 80E5 USB Port Replacement: adım 14, 3 resimden 2. Lenovo G50-80 80E5 USB Port Replacement: adım 14, 3 resimden 3.
    • Remove the three motherboard fixing screws (#00x5.5mm) and remove the motherboard.
  15. Lenovo G50-80 80E5 USB Port Replacement, USB Port: adım 15, 1 resimden 1.
    • These joints will have to be soldered for removal
Sonuç
Bir başkası bu kılavuzu tamamladı.
Victor
1.282 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 UMass Dartmouth, Team S1-G6, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G6
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
What kind of port is this? THT/SMD? THT even or scrambled( offset ) set of THT elements? Four latch pins make it look like: https://cy.rsdelivers.com/product/wurth-...
Bartosz Baranowski - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 3,531
