Ana içeriğe geç
Lenovo IdeaPad 100s-14IBR Battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 100s-14IBR Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Battery Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 100s-14IBR Battery Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Battery Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad 100s-14IBR Battery Replacement: adım 3, 2 resimden 2.
    • Remove six 4mm Phillips #00 screws.
    • Pull the battery connector parallel to the motherboard to disconnect the battery from the motherboard.
  4. Lenovo IdeaPad 100s-14IBR Battery Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad 100s-14IBR Battery Replacement: adım 4, 2 resimden 2.
    • Use a nylon spudger to pry the battery up and out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mohammed Younis
421 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 4,160
