Giriş
Use this guide to replace a broken fan in your Lenovo IdeaPad 3-15IIL05 laptop.
You may need to replace the fan if your laptop is overheating.
Neye ihtiyacın var
Unplug all cables and fully shut down your laptop.
Use a Phillips screwdriver to remove the ten screws securing the back cover:
Six 7.6 mm-long screws
Four 4.7 mm-long screws
Insert the flat side of an opening pick between the top left corner of the back cover and frame.
Angle the pick down to about 45 degrees.
Slide the pick to the bottom left corner of the laptop to release the left clips.
Slide the opening pick to the bottom right corner to release the bottom clips.
Slide the opening pick to the top right corner to release the right clips.
Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
Pry the back cover up with the pick to release the top right clips.
Leave the pick inserted next to the right hinge.
Angle the pick up to about 45 degrees.
Slide the opening pick to the top left corner to release the remaining clips.
Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
Push on alternating sides of the fan cable connector with a spudger to "walk" it out of its socket.
Bu adımda kullanılan alet:Tweezers$3.99
Slide one arm of your angled tweezers under the head of the gray antenna cable connected to the WLAN card.
Gently lift straight up to disconnect the cable.
Repeat the same process to disconnect the black antenna cable.
Use a Phillips screwdriver to remove the three screws securing the fan:
Two 4.4 mm-long screws
One 5.6 mm-long screw
Lift the fan up and gently guide the black and gray antenna cables out of their clips on the edge of the fan.
Remove the fan.
Check your repair by running hardware tests with Lenovo Diagnostics.
