Ana içeriğe geç
Lenovo IdeaPad 3-15IIL05 RAM Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Unfasten the back cover: adım 2, 2 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Unfasten the back cover: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: adım 3, 3 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: adım 3, 3 resimden 2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: adım 4, 3 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: adım 4, 3 resimden 2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: adım 4, 3 resimden 3.
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: adım 5, 3 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: adım 5, 3 resimden 2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: adım 5, 3 resimden 3.
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: adım 6, 3 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: adım 6, 3 resimden 2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: adım 6, 3 resimden 3.
    • Slide the opening pick to the top right corner to release the right clips.
  7. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: adım 7, 2 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: adım 7, 2 resimden 2.
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: adım 8, 3 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: adım 8, 3 resimden 2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: adım 8, 3 resimden 3.
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: adım 9, 3 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: adım 9, 3 resimden 2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: adım 9, 3 resimden 3.
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: adım 10, 3 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: adım 10, 3 resimden 2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: adım 10, 3 resimden 3.
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
  11. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: adım 11, 3 resimden 1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: adım 11, 3 resimden 2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: adım 11, 3 resimden 3.
    • Two metal arms secure the stick of RAM.
    • Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
    • Remove the stick of RAM.
    • To install a stick of RAM, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the stick in place.
Sonuç
Check your repair by running hardware tests with Lenovo Diagnostics.
Bir başkası bu kılavuzu tamamladı.
Spencer Day
55.149 İtibar
408 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.410 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 48
Son 30 gün: 140
Her zaman: 765
