Giriş
Use this guide to replace the speakers in your Lenovo IdeaPad 3-15IIL05 laptop.
Your speakers may need to be replaced if they're crackling, have poor quality or aren't making any noise.
Note: The left and right speakers are connected by a cable and must be removed as one. Replacing one speaker requires replacing both of them.
Neye ihtiyacın var
Unplug all cables and fully shut down your laptop.
Use a Phillips screwdriver to remove the ten screws securing the back cover:
Six 7.6 mm-long screws
Four 4.7 mm-long screws
Insert the flat side of an opening pick between the top left corner of the back cover and frame.
Angle the pick down to about 45 degrees.
Slide the pick to the bottom left corner of the laptop to release the left clips.
Slide the opening pick to the bottom right corner to release the bottom clips.
Slide the opening pick to the top right corner to release the right clips.
Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
Pry the back cover up with the pick to release the top right clips.
Leave the pick inserted next to the right hinge.
Angle the pick up to about 45 degrees.
Slide the opening pick to the top left corner to release the remaining clips.
Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
Push on alternating sides of the speaker cable connector with a spudger to "walk" it out of its socket.
Guide the speaker wire out of the two metal clips securing it to the frame.
Check your repair by running hardware tests with Lenovo Diagnostics.
