Ana içeriğe geç
Lenovo IdeaPad Flex 4-1470 Battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: adım 1, 1 resimden 1.
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Battery Replacement: adım 2, 2 resimden 2.
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: adım 5, 1 resimden 1.
    • Lift the battery up and out of the laptop.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Demario Robinson
1.038 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G6
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - Yanıt
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 37
Her zaman: 13,871
