Ana içeriğe geç
Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 2, 3 resimden 3.
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 3, 2 resimden 2.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Battery: adım 4, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 5, 3 resimden 3.
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Daughterboard: adım 6, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Daughterboard: adım 6, 2 resimden 2.
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 7, 2 resimden 2.
    • Using the plastic opening tool, disconnect the CMOS battery from the daughterboard by pushing it out towards the direction of the CMOS battery.
  8. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the single 5 mm screw.
  9. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 9, 1 resimden 1.
    • Using the iFixit Opening tool, remove the silver piece of tape from the device.
  10. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 10, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: adım 10, 2 resimden 2.
    • Lift the daughterboard up and out of the device.
Sonuç
Justin Ogihara
29.139 İtibar
52 adet Kılavuz yazıldı
Ekip
EDU Team EDU Team üyesi
Staff
7 Üyeler
756 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 494
