Ana içeriğe geç
Lenovo IdeaPad Flex 5-1570 Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Fan Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Fan Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Fan Replacement: adım 2, 3 resimden 3.
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Fan Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Fan Replacement: adım 3, 2 resimden 2.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Fan: adım 4, 1 resimden 1.
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 Fan Replacement: adım 5, 1 resimden 1.
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 Fan Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Fan Replacement: adım 6, 2 resimden 2.
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Will Schafer
380 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G6, White Winter 2020 Cal Poly, Team S2-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S2G6
4 Üyeler
13 adet Kılavuz yazıldı
1Rehber Yorum
thank you for you share
Liu bing - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 2,632
