Giriş
A faulty fan in the Lenovo IdeaPad Flex 5-1570 is a problem on its own but can also cause more serious problems for the device. Whether your fan is making noise, permanently damaged, or just simply won’t work, this guide will show you how to easily remove and replace it.
Neye ihtiyacın var
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
Once all the clips have been disengaged, lift off the back cover.
You should probably disconnect the battery immediately after opening the laptop. Don’t want to risk damaging your nice hardware.
2 farklı kişi bu kılavuzu tamamladı.
