Ana içeriğe geç
Lenovo IdeaPad Flex 5-1570 Speaker Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 2, 3 resimden 3.
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 3, 2 resimden 2.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  5. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 5, 2 resimden 2.
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  6. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: adım 6, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: adım 6, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 7, 2 resimden 2.
    • Using your hands, gently pull the left speaker up and out of the device.
  8. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: adım 8, 2 resimden 2.
    • Repeat the previous step for the other speaker and remove the speakers from the device.
Sonuç
Nate Blake
507 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G6, White Winter 2020 Cal Poly, Team S2-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S2G6
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 564
