Ana içeriğe geç
Lenovo IdeaPad Flex 5-1570 Touchpad Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 2, 3 resimden 3.
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 3, 2 resimden 2.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: adım 4, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 5, 3 resimden 3.
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: adım 6, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: adım 6, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: adım 6, 3 resimden 3.
    • Using the plastic opening tool, unlock the four ZIF connectors to release the flat cables.
    • Disconnect the four flat cables from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 7, 1 resimden 1.
    • Using the JIS #000 screwdriver, remove six 2mm screws holding the trackpad down to the device.
  8. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 8, 1 resimden 1.
    • Using the plastic opening tool, remove the silver piece of tape holding the touchpad to the device.
  9. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 9, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 9, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: adım 9, 3 resimden 3.
    • Insert the plastic opening tool underneath the touchpad.
    • Lift it up and remove the touchpad from the device.
Sonuç
Justin Ogihara
29.148 İtibar
52 adet Kılavuz yazıldı
Ekip
EDU Team EDU Team üyesi
Staff
7 Üyeler
770 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 18
Son 30 gün: 61
Her zaman: 2,031
