Ana içeriğe geç
Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement, Heat Sink: adım 1, 1 resimden 1.
    • Flip the Lenova ideapad onto its back and remove the screws using a screwdriver with a PH0 bit. All screws will use this bit.
    • 8 (5.35mm long screws)
    • 2 (15.37mm long screws)
    • 1 (5.63mm long screw)
  2. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: adım 2, 2 resimden 2.
    • Firmly pull the cover off and locate the screws circled in red. These screws will stay attached to the old heat sink.
    • Loosen each screw until an audible click can be heard. The screws do not need to be fully removed from the old heat sink.
  3. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: adım 3, 1 resimden 1.
    • Carefully grab the heat sink and lift it straight up. This is to prevent spreading thermal paste.
  4. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: adım 4, 1 resimden 1.
Sonuç
With all steps completed test the Lenova Ideapad to ensure it is properly working. It is recommended to run intensive applications while monitoring internal temperatures. This will show if the cooling system is properly working.
Blake Ludge
109 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Spring 2023 IUPUI, Team 3-1, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S3G1
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 223
