Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Use this guide to replace the IO board.
  1. Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Remove SD card if present. Remove two black 3mm Phillips #00 screws.
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing. Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Remove seven black 3mm Phillips #00 screws. The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Now you can take the battery out in order to either replace it or continue disassembling the device. Now you can take the battery out in order to either replace it or continue disassembling the device.
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  7. Remove two black 3mm Phillips #00 screws. Remove three silver 1.8 mm Phillips #00 screws. Remove three silver 1.8 mm Phillips #00 screws.
    • Remove three silver 1.8 mm Phillips #00 screws.
  8. Use tweezers to flip up the small black plastic locks on all four connections. Carefully remove each of the exposed ribbons. Carefully remove each of the exposed ribbons.
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  9. Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing. Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  10. Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector. Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  11. Disconnect the HDMI connection with the system board Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free. Slide out the system board from its housing tab on the upper right corner.
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  12. Remove the following two screws: M 5.3 x 1.75 mm #00 phillips screws (silver)
    • Remove the following two screws:
    • M 5.3 x 1.75 mm #00 phillips screws (silver)
  13. Once the screws are out, use the tweezers to pull the board straight out.
    • Once the screws are out, use the tweezers to pull the board straight out.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Brian
565 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G19
4 Üyeler
14 adet Kılavuz yazıldı
6 Yorum
Great guide but make sure you REMOVE THE AUX SD CARD FIRST if installed or you will break the card and or card slot.
Other than that, no problems. I got the io board for $26 and I put it in for free.
James Bush - Yanıt
I need an io board for cheap... I might have to make a guide on how to attempt to repair io card without proper tools and a filed down soldering iron tip
Ember Leona - Yanıt
Thank you this was helpful. I think I fixed my screen flickers the LCD ribbon is under the battery and the ribbon from the volume board on the right I think that's related to the screen rotation lock. Those needed to be flipped up and reseated. Thanks
Ember Leona - Yanıt
Thanks Very much
the guide is very clear
i have done the job successfully
omimh - Yanıt
Excelente guía. Muchas gracias.
Larry Pacheco - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 4,603
