Ana içeriğe geç
Lenovo Ideapad 320-15ABR Battery Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad 320-15ABR Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Battery Replacement: adım 2, 3 resimden 1. Lenovo Ideapad 320-15ABR Battery Replacement: adım 2, 3 resimden 2. Lenovo Ideapad 320-15ABR Battery Replacement: adım 2, 3 resimden 3.
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Battery Replacement: adım 3, 2 resimden 1. Lenovo Ideapad 320-15ABR Battery Replacement: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Battery Replacement: adım 4, 3 resimden 1. Lenovo Ideapad 320-15ABR Battery Replacement: adım 4, 3 resimden 2. Lenovo Ideapad 320-15ABR Battery Replacement: adım 4, 3 resimden 3.
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Battery Replacement: adım 5, 3 resimden 1. Lenovo Ideapad 320-15ABR Battery Replacement: adım 5, 3 resimden 2. Lenovo Ideapad 320-15ABR Battery Replacement: adım 5, 3 resimden 3.
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Battery Replacement, Battery: adım 6, 1 resimden 1.
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Battery Replacement: adım 7, 2 resimden 1. Lenovo Ideapad 320-15ABR Battery Replacement: adım 7, 2 resimden 2.
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Battery Replacement: adım 8, 1 resimden 1.
    • Remove the battery.
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Anurag Deb
1.048 İtibar
3 adet Kılavuz yazıldı
4 Yorum
hi
can i change the original battery with a more powerful battery?
amin - Yanıt
Votre explication est très bien détaillée et très explicite. Merci beaucoup vous m'avez vraiment aidé.
Ulrich Foudjin - Yanıt
I can't get past the first step...pulling out the optical card. The rest I think I can do because I have done things like this before. I unscrewed the screw bu can't pull it out.
Peg Thompson - Yanıt
Unclip the tiny clips from where you removed the optical card. The back will come off
TopStuff Anime -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 155
Son 30 gün: 1,039
Her zaman: 76,385
