Ana içeriğe geç
Lenovo Ideapad 320-17IKB LED Screen Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad 320-17IKB LED Screen Replacement, LED Screen: adım 1, 3 resimden 1. Lenovo Ideapad 320-17IKB LED Screen Replacement, LED Screen: adım 1, 3 resimden 2. Lenovo Ideapad 320-17IKB LED Screen Replacement, LED Screen: adım 1, 3 resimden 3.
    • Start from the left side of the bezel (plastic covering) by gently removing inner edge of the plastic. Continue to do the same thing on the right side.
  2. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 2, 3 resimden 1. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 2, 3 resimden 2. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 2, 3 resimden 3.
    • Turn the laptop sideways and insert the plastic pick between the bezel (plastic covering) and the laptop cover. Use the plastic pick to separate the bezel from the top cover.
  3. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 3, 3 resimden 1. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 3, 3 resimden 2. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 3, 3 resimden 3.
    • Remove the bezel (plastic covering) from the laptop completely and set aside.
    • Do not twist or bend the LED screen or the bezel. Doing so could result in permanent damage to the LED screen or injury to yourself.
  4. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 4, 3 resimden 1. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 4, 3 resimden 2. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 4, 3 resimden 3.
    • Remove the four 7mm JIS #00 screws from each corner while holding the screen in place.
  5. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 5, 3 resimden 1. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 5, 3 resimden 2. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 5, 3 resimden 3.
    • Place the LED screen on the keyboard and use your fingers or the iFixit opening tool to open the bracket securing the video connector. Then, disconnect the video cable.
  6. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 6, 2 resimden 1. Lenovo Ideapad 320-17IKB LED Screen Replacement: adım 6, 2 resimden 2.
    • Once all the other steps have been completed you should have a disconnected LED screen, and bezel. The connector tab should remain adhered to the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Is there a direct replacement better quality panel?
Jason - Yanıt
does this laptop have backlights on keyboard ????????
P SANDEEP - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 1,602
