Ana içeriğe geç
Lenovo Ideapad Flex 4-1570 Battery Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad Flex 4-1570 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Battery Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Battery Replacement, Battery: adım 4, 2 resimden 1. Lenovo Ideapad Flex 4-1570 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Lenovo Ideapad Flex 4-1570 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Isaiah Vang
669 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G6
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 1,686
