Giriş
Use this guide to upgrade or replace the right side M.2 solid-state drive (SSD) in a Lenovo Legion 5 Pro 16ACH6H gaming laptop. This laptop is only compatible with NVME SSDs, and is therefore not compatible with SATA SSDs.
Before you perform this repair, back up your existing SSD if possible. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Finally, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Neye ihtiyacın var
Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
Six 12.7 mm PH00 screws
Four 4.2 mm PH00 screws
Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
Angle the pick to about 30˚ and slide down the right edge until you reach the plastic vents on the side.
Repeat the same procedure on the left edge to release the clips.
Position the laptop vertically so you can easily access the plastic vents.
Slide the rounded edge of an opening pick between the frame and the plastic vents on the right side near the USB-A port.
Rotate the pick so that it is positioned on top of the plastic vents.
Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
Use the pointed end of a spudger to push each side of the battery connector to loosen it.
Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the right SSD shield to the motherboard.
Grip the edges of the SSD near the screw indent.
Gently pull to remove the SSD.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
7 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Warning! There are PCI Express 1.3 and PCI Express 1.4. 3.5 mm is max for SSD for PCI Express 1.3, ~2.5 mm is for PCI Express 1.4. SSD for PCI Express 1.4 must not have chips on the bottom due to there is no space to place SSD.
