Ana içeriğe geç
Lenovo Legion Y520-15IKBN Base Panel Replacement
Neye ihtiyacın var
  1. Lenovo Legion Y520-15IKBN Base Panel Replacement, Base Panel: adım 1, 2 resimden 1. Lenovo Legion Y520-15IKBN Base Panel Replacement, Base Panel: adım 1, 2 resimden 2.
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Base Panel Replacement: adım 2, 1 resimden 1.
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Connor
12.663 İtibar
64 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.664 adet Kılavuz yazıldı
1Rehber Yorum
I was wondering, do you know the gauge of the the 13 case screws? I'm trying to replace some I've lost for the case as well as the interior screws around the fan and heatsink.
Samuel Anklin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 40
Her zaman: 1,243
