Ana içeriğe geç
Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement
Neye ihtiyacın var
  1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: adım 1, 3 resimden 1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: adım 1, 3 resimden 2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: adım 1, 3 resimden 3.
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: adım 2, 2 resimden 1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Sonuç
Bir başkası bu kılavuzu tamamladı.
3 Yorum
This is only for the key caps, what about the keyboard itself?
Rick Montoya - Yanıt
I agree the video is mislabeled. You are not replacing the board just keys.
Pat Schutte - Yanıt
Please create a tutorial for keys with stabilizer like space bar and enter keys.
Affix - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 28
Son 30 gün: 77
Her zaman: 11,504
