Ana içeriğe geç
Lenovo Legion Y7000P RAM Replacement
Neye ihtiyacın var
  1. Lenovo Legion Y7000P RAM Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Lenovo Legion Y7000P RAM Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo Legion Y7000P RAM Replacement, Flip your laptop over: adım 2, 1 resimden 1.
    • Flip your laptop over so the rubber feet are facing up.
  3. Lenovo Legion Y7000P RAM Replacement, Unfasten the back cover: adım 3, 2 resimden 1. Lenovo Legion Y7000P RAM Replacement, Unfasten the back cover: adım 3, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
    • Five 11.5 mm‑long screws
    • Six 4.7 mm-long screws
  4. Lenovo Legion Y7000P RAM Replacement, Insert an opening pick: adım 4, 2 resimden 1. Lenovo Legion Y7000P RAM Replacement, Insert an opening pick: adım 4, 2 resimden 2.
    • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
  5. Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: adım 5, 3 resimden 1. Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: adım 5, 3 resimden 2. Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: adım 5, 3 resimden 3.
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Keep the pick angled upwards while sliding to help release the clips.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Lenovo Legion Y7000P RAM Replacement: adım 6, 3 resimden 1. Lenovo Legion Y7000P RAM Replacement: adım 6, 3 resimden 2. Lenovo Legion Y7000P RAM Replacement: adım 6, 3 resimden 3.
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Lenovo Legion Y7000P RAM Replacement, Remove the back cover: adım 7, 3 resimden 1. Lenovo Legion Y7000P RAM Replacement, Remove the back cover: adım 7, 3 resimden 2. Lenovo Legion Y7000P RAM Replacement, Remove the back cover: adım 7, 3 resimden 3.
    • Remove the back cover.
  8. Lenovo Legion Y7000P RAM Replacement, Reassembly information: adım 8, 3 resimden 1. Lenovo Legion Y7000P RAM Replacement, Reassembly information: adım 8, 3 resimden 2. Lenovo Legion Y7000P RAM Replacement, Reassembly information: adım 8, 3 resimden 3.
    • During reassembly:
    • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
    • Press down firmly around the perimeter of the back cover to engage all the clips.
  9. Lenovo Legion Y7000P RAM Replacement, Heat the black cover: adım 9, 2 resimden 1. Lenovo Legion Y7000P RAM Replacement, Heat the black cover: adım 9, 2 resimden 2.
    • A stiff, black cover runs across the heatsink and fans.
    • Removing the cover makes repairs much easier, but isn't required. If you don't want to remove the cover, you can roll it onto itself to keep it out of the way and skip the next two steps.
    • Heat an iOpener and apply it to the cover for two minutes.
    • You can also use a hair dryer. Follow this guide for more instructions.
  10. Lenovo Legion Y7000P RAM Replacement, Remove the cover: adım 10, 3 resimden 1. Lenovo Legion Y7000P RAM Replacement, Remove the cover: adım 10, 3 resimden 2. Lenovo Legion Y7000P RAM Replacement, Remove the cover: adım 10, 3 resimden 3.
    • Gently peel up and remove the black cover.
    • During reassembly, press the cover back into place using the residual adhesive.
  11. Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: adım 11, 3 resimden 1. Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: adım 11, 3 resimden 2. Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: adım 11, 3 resimden 3.
    • Use the flat end of a spudger to push the battery connector straight out of its socket.
    • Push the tab on top of the battery connector, not the wires themselves.
  12. Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: adım 12, 3 resimden 1. Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: adım 12, 3 resimden 2. Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: adım 12, 3 resimden 3.
    • A metal shield covers the sticks of RAM.
    • Use a spudger to pry up the left side of the metal shield.
  13. Lenovo Legion Y7000P RAM Replacement, Remove the metal shield: adım 13, 2 resimden 1. Lenovo Legion Y7000P RAM Replacement, Remove the metal shield: adım 13, 2 resimden 2.
    • Remove the metal shield.
    • During reassembly, align the shield with its metal clips and press down firmly around the perimeter to secure the shield.
  14. Lenovo Legion Y7000P RAM Replacement, Remove the RAM: adım 14, 3 resimden 1. Lenovo Legion Y7000P RAM Replacement, Remove the RAM: adım 14, 3 resimden 2. Lenovo Legion Y7000P RAM Replacement, Remove the RAM: adım 14, 3 resimden 3.
    • Two metal arms secure each stick of RAM.
    • Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
    • Remove the stick of RAM.
    • Repeat the process to remove the other stick of RAM.
    • To install a stick of RAM, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the stick in place.
Sonuç
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
95.703 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.539 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 52
Son 30 gün: 334
Her zaman: 722
