Ana içeriğe geç
Lenovo Tab 4 TB-8504F Vibrator Replacement
Neye ihtiyacın var
  1. Lenovo Tab 4 TB-8504F Vibrator Replacement, Battery: adım 1, 3 resimden 1. Lenovo Tab 4 TB-8504F Vibrator Replacement, Battery: adım 1, 3 resimden 2. Lenovo Tab 4 TB-8504F Vibrator Replacement, Battery: adım 1, 3 resimden 3.
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 2, 3 resimden 1. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 2, 3 resimden 2. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 3, 2 resimden 1. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 3, 2 resimden 2.
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 4, 3 resimden 1. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 4, 3 resimden 2. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 4, 3 resimden 3.
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 TB-8504F Vibrator Replacement, Vibrator: adım 5, 2 resimden 1. Lenovo Tab 4 TB-8504F Vibrator Replacement, Vibrator: adım 5, 2 resimden 2.
    • Remove 16 screws from the midframe with Phillips #000 screwdriver [bit].
  6. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 6, 3 resimden 1. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 6, 3 resimden 2. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 6, 3 resimden 3.
    • Using an opening pick, find a spot to lift the bracket around the tablet.
    • When the opening pick is inserted between the bracket and tablet, move the pick around the whole tablet to completely detach the bracket.
  7. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 7, 3 resimden 1. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 7, 3 resimden 2. Lenovo Tab 4 TB-8504F Vibrator Replacement: adım 7, 3 resimden 3.
    • Using the soldering iron can be very dangerous if not used carefully. Solder iron is very hot.
    • Desolder the blue and red wires from the motherboard.
    • Once wires are detached, use a metal spudger tool to lift the vibrator.
    • If the wire is not detaching from the tin, raise the heat on the soldering iron.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 851
