Ana içeriğe geç
Lenovo ThinkPad Edge E420s Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad Edge E420s Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Hard Drive Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad Edge E420s Hard Drive Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: adım 3, 3 resimden 3.
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Hard Drive Replacement: adım 4, 1 resimden 1.
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Hard Drive Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad Edge E420s Hard Drive Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: adım 5, 3 resimden 3.
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 2,863
